How to trigger Sub flow (Flow designer) using business rules
Madhan27
Mega Guru
I am trying to create a business to trigger Sub flow for an closed alert,  I copied the flow designer code snippet and pasted in the business rules but I am not getting what are the values to be given for the below following.
Thanks in advance.
Madhan27
Mega Guru
We need to set the conditions when to run and in actions with the below following script its calling the flow designer on closed alerts.
    (function() {
        try {
            var inputs = {};
            inputs['ah_alertrulename'] = 'ICO Fault Management Flow';
            inputs['ah_alertruleid'] = 'dee9da63873971d035a90e96cebb3530';
            inputs['ah_alertgr'] = current;
            var result = sn_fd.FlowAPI.getRunner().subflow('global.ico_fault_management_flow').inForeground().withInputs(inputs).run();
            var outputs = result.getOutputs();
        } catch (ex) {
            var message = ex.getMessage();
            gs.error(message);
Madhan27
Mega Guru
    (function() {
        try {
            var inputs = {};
        } catch (ex) {
            gs.error(message);
