04-07-2026 08:37 AM
Hi Team,
I have an Excel file with the following columns and approximately 300 rows:
Owners (Users)
Groups (Group Names)
Active
Example:
Owners | Groups
User 1 | SSO Group A
User 2 | SSO Group B
User 10 | SSO Group J
Like this, there are approximately 300 rows with duplicate user-group combinations.
I want to achieve the following from scratch using Import Set:
Create Users in sys_user (if not exists) — I was able to create successfully using Coalesce
Create Groups in sys_user_group (if not exists) — I was able to create successfully using Coalesce
Create Group Membership in sys_user_grmember — I am unable to create
Avoid duplicate records
I tried using multiple Transform Maps, but group membership is not getting created properly. The Group value is populated, but the User field is empty in sys_user_grmember.
Any guidance or example would be very helpful.
Thanks in advance.
04-07-2026 01:08 PM
I don't see anything utterly wrong :// only thing to review from my end would be "name" on [sys_user] table because the Name is calculated [First name + Last name], so populating directly the Name could bring some mess.. you can try to add more columns and to have it separately for each column/field.
But if users are created correctly then you can ignore this..
could you share the transform map for sys_user_grmember, especially the fields that are coalesce?
04-08-2026 10:53 PM
Hi @Kishore47
The cell split into two columns can be done directly in the excel as well. I never remember the formula but google can help.
So it all worked good? 🙏
