01-29-2024 01:14 AM
As Incidents are reopen again and again after the resolution from 2021, anyone please help me to sort-out this issue.
01-29-2024 01:45 AM
So you have incoming alerts through which incidents are being created. Though the incident is revolving around the same CI or have similar intent, their is no correlation being done and individual incidents are being created for every alert.
If this is the case, you should check if you can have the correlation being enabled on the source monitoring tool or setup the alert correlation rules https://docs.servicenow.com/bundle/vancouver-it-operations-management/page/product/event-management/...
Thanks & Regards
Amit Verma
01-29-2024 02:56 AM
01-29-2024 02:37 AM
You can refer below support articles and take the decision accordingly :
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0756521
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0997625
Thanks & Regards
Amit Verma
01-29-2024 02:47 AM
As per your solution, Multiple alerts for the same issue create the respective incidents, but in my case same alert is reopen which increase the incident reopen count.
01-29-2024 02:56 AM
