Issue with Data Stream in Flow Designer (Could not retrieve snapshot for test)
Tomko
I have built and successfully executed a REST Action that pulls server data from an external application (CloudCheckr).
While I could build an action to parse the JSON that is being returned, it seems like a better approach would be to use a Data Stream.
I've built a Data Stream with no preprocessing, no paging, and the same REST message and configuration as the standalone REST action mentioned previously, but when I run this Action in a flow that doesn't do anything else, I am immediately getting:
There was an error executing the flow:Internal Server Error
My logs show the stack trace below.
I'm not even sure where to start troubleshooting this.
com.glide.flow_trigger.engine.FlowSnapshotPlanRetriever.retrieve(FlowSnapshotPlanRetriever.java:33)
com.snc.process_flow.engine.serialization.PlanProxy.plan(PlanProxy.java:43)
com.snc.process_flow.engine.PFContext.init(PFContext.java:275)
com.snc.process_flow.engine.GlideProcessAutomation._init(GlideProcessAutomation.java:400)
com.snc.process_flow.engine.GlideProcessAutomation.lambda$runAsUserSync$1(GlideProcessAutomation.java:210)
com.snc.process_flow.engine.GlidePFSession.runPlanAsUserSession(GlidePFSession.java:40)
com.snc.process_flow.engine.GlideProcessAutomation.runAsUserSync(GlideProcessAutomation.java:205)
com.snc.process_flow.engine.GlideProcessAutomation.messageFlow(GlideProcessAutomation.java:242)
com.snc.process_flow.engine.GlideProcessAutomation._start(GlideProcessAutomation.java:364)
com.snc.process_flow.engine.GlideProcessAutomation.access$400(GlideProcessAutomation.java:82)
com.snc.process_flow.engine.GlideProcessAutomation$StartBuilder.start(GlideProcessAutomation.java:898)
com.glide.flow_trigger.engine.TestButtonTriggerRunner.run(TestButtonTriggerRunner.java:168)
com.glide.flow_trigger.engine.TestButtonTriggerRunner.test(TestButtonTriggerRunner.java:172)
com.glide.flow.providers.FlowGlideProvider.testFlow(FlowGlideProvider.java:992)
com.glide.flow_design.rest.FlowService.testRunFlow(FlowService.java:573)
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
java.lang.reflect.Method.invoke(Method.java:498)
com.glide.rest.handler.impl.ServiceHandlerImpl.invokeService(ServiceHandlerImpl.java:44)
com.glide.rest.processors.RESTAPIProcessor.process(RESTAPIProcessor.java:290)
com.glide.processors.AProcessor.runProcessor(AProcessor.java:553)
com.glide.processors.AProcessor.processTransaction(AProcessor.java:240)
com.glide.processors.ProcessorRegistry.process0(ProcessorRegistry.java:177)
com.glide.processors.ProcessorRegistry.process(ProcessorRegistry.java:166)
com.glide.ui.GlideServletTransaction.process(GlideServletTransaction.java:31)
com.glide.sys.Transaction.run(Transaction.java:2192)
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
java.lang.Thread.run(Thread.java:748)
Ashutosh Munot1
can you check this:
https://hi.service-now.com/kb_view.do?sysparm_article=KB0854481
Ashutosh
Tomko
Thanks Ashutosh -
That gives me someplace to start.
Nice
