Power shell execution using large strings as arguments
tmiya
If I want to run powershell on MID from ServiceNow, the name field of the ECC queue should be What I can do with the form "script.ps1 +argument" is I know. (script.ps1 has been placed in MID in advance)
However, if the argument is too long, the string will be cut off and cannot be executed correctly.
Does anyone know how to pass long arguments to powershell without cutting the string?
The arguments change dynamically, so they are not fixed values. (Acquired from input values ​​such as applications)
tmiya
tmiya
jamy2
How did you solve this?
