Service Mapping Advanced lab doubt(Lab 6.12: Create Pattern Identification section for JBoss WildFl)
Rajanigandha
Lab 6.12: Create Pattern Identification section for JBoss WildFly Part 4
For the above mentioned lab, I have successfully followed all the steps mentioned in lab course and also successfully tested them. However, I am still getting Task Validation as failed.  Can anyone help me understand why I am facing this issue.
Below are the screenshots for reference:
error screenshot.pngexpected result screenshot from course.pngMy Pattern confirguration screenshot.pngMy test successful result.png
SK Chand Basha
Hi @Rajanigandha
Follow the same naming convention, case sensitive use deployments instead of Deployments.
If not sloved raise a case.
Mark it helpful and accept solution if this helps you to understand.
Hi @Rajanigandha
If it is solved the issue Mark it accept solution! And close the 🔁
Amit Sharma7
Hi @Rajanigandha
As mentioned by SK please ensure to make the case as well as i noticed one more thing, which was the error in my case.  In the XML file select the deployment name not the runtime-name, however both of them has the same value.
Select the one highlighted as green , do not select the one highlighted in red.
Hope this helps.
Thank You
Amit
Hi @Rajanigandha
Good day
I am new to Service Mapping and started on demand learning,
I was stuck in the Get Deployment steps the Parse file command is not retrieving the XML file data
Please find the screenshot below and help me to move further
Thanks in advance for your help
