‎01-19-2017 12:46 PM
Is there a list that contains a description for the fields in ServiceNow as it relates to Configuration Management?
‎01-20-2017 12:10 PM
Ok.. let's do it another way. In the left navigator, type sys_documentation.list:
It will open the Field Label table:
Put cmdb in the table search and hit enter:
That will give you practically every field in the cmdb (cmdb_ci is the base table and there are a lot that extend off that, but they all start with cmdb).
I just removed the empty hints, but that is where you will get your information.
‎01-20-2017 11:53 AM
Oh, great! You are in the right place, then. Go here: https://developer.servicenow.com/
and get yourself your own instance to play around in.
‎01-20-2017 11:55 AM
Here is some more info:
https://community.servicenow.com/search.jspa?q=developer%20site
It will be your own personal site once you get one. You can mess up and reset it as much as you want. There is also training documentation there.
‎01-20-2017 12:01 PM
Thanks so much! This is super silly!! I have Sandbox environment set up through my company so I am playing with an instance. The problem is I want to access that link you sent to maybe view the field by field definitions but it seems like it isn't working for me. I appreciate all you have done so far... just seems a challenge to get a link LOL!
‎01-20-2017 01:06 PM
YEAH!!!! it worked! I had to create my own instance so I could have complete admin rights. You have gone above and beyond to help me! I so appreciate it. I do have one more question. Is there a way to extract the CMDB fields in a spreadsheet so I can do a comparison. Its awesome because i have backend field names as well.
