System fields are not populating from transform maps import.
Shruti Bhosale
I am creating case records from record producer.
I am calling cart api to place order from record producer. but it is populating only variables under variable editor but it is not setting assignment group or assigned ,comments to fields.
please suggest.
12 REPLIES 12
Shruti Bhosale
we are loading case data records which should call record producer for variables and import case records.
Shruti Bhosale
(function runTransformScript(source, map, log, target /* GlideRecord */ ) {
    var item = gs.getProperty('sn_customerservice.record producer');
    var sub = source.u_subject.getDisplayValue();
    var des = source.u_description.getDisplayValue();
    var num = source.u_number.getDisplayValue();
    var x;
    var acc;
    var ref = new GlideRecord("sys_user"); //Replace sys_user with any reference table
    ref.addQuery("email", source.u_contact); //Replace email with any unique field
    ref.query();
    if (ref.next()) {
        x = ref.getValue('sys_id');
        acc = ref.getValue('company');
        var cart = new sn_sc.CartJS();
        var item = {
            'sysparm_id'item,
            'sysparm_quantity''1',
            'variables': {
                'short_description': sub,
                'description': des,
                'number': num,
                'contact': x,
                'request_type': source.u_request_type.getDisplayValue(),
                'u_bma_updated': source.u_bma_updated.getDisplayValue(),
             {"cause":"Test"
        var cartVals = cart.addToCart(item); /
        var checkoutVals = cart.checkoutCart();
        ignore = true;
})(source, map, log, target);
Shruti Bhosale
tried this
 {"cause":"Test"
no luck
Ankur Bawiskar
@Shruti Bhosale
cart API cannot set assignment group, assigned to etc
you need to explicitly update those
var x;
var acc;
ref.query();
if (ref.next()) {
var item = {
'sysparm_id': item,
'sysparm_quantity': '1',
'variables': {
'description': des,
'number': num,
'contact': x,
var parsedData = JSON.parse(checkoutVals);
var caseSysId = parsedData.request_id;
var gr = new GlideRecord("case table");
gr.addQuery("sys_id", caseSysId);
if (gr.next()) {
gr.assignment_group = ''; // give the group sysId here
gr.assigned_to = ''; // give the group member (user) sysId here
gr.update();
ignore = true;
