Access control script help
11-06-2024 05:33 AM
I cant seem to get this script to work, what I'm trying to achieve is...
I've created a custom table called u_nda_register, on that table it holds fields u_project (referenced to: pm_project) and u_authorized_group (referenced to: sys_user_group)
What I want to happen is if a user goes to the pm_project table and the project matches one which is on the u_nda_register table and is part of the assignment group populated in u_authorized group they will be able to view the record. Otherwise it wont be visible.
(function() {
var ndagr = new GlideRecord('u_nda_register');
ndagr.addQuery('u_project', current.sys_id);
ndagr.query();
if (ndagr.next()) {
var authgroup = ndaRecord.u_authorized_group;
var graccess = gs.getUser().isMemberOf(authorizedGroup);
var userprj = gs.getUser().getPreference('current_project');
if (current.sys_id == userprj && graccess) {
answer = true;
answer = false;
11-06-2024 05:40 AM
@Community Alums
what are you trying to check using this?
11-06-2024 06:04 AM
Ankur! Wow, still going strong on the community! Love the dedication.
With var userprj = gs.getUser().getPreference('current_project'); I was clutching at straws trying to get something to work.
I've tried the below script proposed by Runjay which to be honest is what I started with but worth another go. Any ideas would be great!
(function() {
ndagr.query();
if (ndagr.next()) {
var graccess = gs.getUser().isMemberOf(authgroup);
if (graccess)
answer = true;
else
answer = false;
}else
answer = false;
11-06-2024 05:50 AM
Hi @Community Alums ,
User below modified script.
(function() {
ndagr.query();
if (ndagr.next()) {
if (graccess)
answer = true;
else
answer = false;
}else
answer = false;
Not sure why are you doing this. Using GR you have already validated that project belongs to u_nda_register table or not.
11-06-2024 06:00 AM
I think that was me just clutching at straws to show for new records! 😀
I've tried this already but still not working.
(function() {
ndagr.query();
if (ndagr.next()) {
if (graccess)
answer = true;
else
answer = false;
}else
answer = false;
