Location Filed is not Updating using Business Rule script
Rajesh Bandila
Hi Everyone,
I have created an After Business rule for the sc_req_item table to update the asset’s Install Status and Location. While the Install Status is updating correctly, the Location (which refers to the cmn_location table) is not updating. The Location should update based on the checkbox selected in the item variable.
Please refer to the script below and help me resolve this issue?
    var gr = new GlideRecord('u_cmdb_ci_workstation');
    gr.addQuery('sys_id', 'IN', current.variables.group);
    while (gr.next()) {
        gr.install_status = '6';
        // Check the FR checkbox and update the location
        if (gr.get(current.variables.FR == true)) {
            gs.log('FR checkbox is checked');
            gr.setValue('location', '05d5a53d6f1721005fa8fbf7eb3ee419'); // Location ID for FR
            gr.setValue('virtual', true);
            gs.log('FR checkbox is not checked');
        // Check the US checkbox and update the location
       if (gr.get(current.variables.US == true)){
            gr.setValue('location', 'another_location_id'); // Replace with the actual Location ID for US
        gr.update();
})(current, previous);
Rajesh
Brad Bowman
Mega Patron
You don't need/want to get the value of the checkbox from the GlideRecord
    while (gr.next()) {
        if (current.variables.FR == true) { //if this doesn't work, try 'true'
       if (current.variables.US == true)){
        gr.update();
If this still isn't working for you, which logs are you seeing?
