Access control script help
I cant seem to get this script to work, what I'm trying to achieve is...
I've created a custom table called u_nda_register, on that table it holds fields u_project (referenced to: pm_project) and u_authorized_group (referenced to: sys_user_group)
What I want to happen is if a user goes to the pm_project table and the project matches one which is on the u_nda_register table and is part of the assignment group populated in u_authorized group they will be able to view the record. Otherwise it wont be visible.
(function() {
    var ndagr = new GlideRecord('u_nda_register');
    ndagr.addQuery('u_project', current.sys_id);
    ndagr.query();
    if (ndagr.next()) {
        var authgroup = ndaRecord.u_authorized_group;
        var graccess = gs.getUser().isMemberOf(authorizedGroup);
        var userprj = gs.getUser().getPreference('current_project');
        if (current.sys_id == userprj && graccess) {
            answer = true;
    answer = false;
Hi @Community Alums ,
Can you share the screenshot of your ACL, It should work. Which type of ACL have you written?
Hey Runjay
See below
@Community Alums
Did you try adding gs.info() and check if it goes inside the query
So you are checking role as well, if both satisfy then it will allow.
Also could you try without (function() {}.
Also run the code in background script and check whether it is going to correct if else or not.
