12-15-2020 04:35 AM
Can anyone suggest me how I can access multi row variable set using REST API explorer.
For single variables, variables.variable_name is working in sysparm_fields. But no luck with multirow variable set.
Request Management
12-15-2020 05:55 AM
Responses below
1. how can I fetch display value of a reference type variable in the multi row variable set.
- not possible as the table only stores sys_id and not display value
2. currently there is a sysparm_limit which is 1 or 10. Can I customize the value. My requirement will exceed 10 for sure.
- this should be fine; when you consume from postman/3rd party tool and don't set the sysparm_limit it should give you all the records
03-31-2021 04:54 AM
So if I want to share api with client then it should be two api? one on catalog item table and other one on sc_multi_row_question_answer?
Shoheb
03-31-2021 05:24 AM
single api for MRVS table
but remember data in that table has sys_id and not display value for reference variables
04-06-2021 01:08 AM
So I created first rest api on requested item table and got the variable values.
Now, i have created another api for MRVS but the variables data present in it are not accessible :
Output:
Where am I going wrong?
Shoheb
04-06-2021 02:14 AM
not accessible means?
04-06-2021 02:17 AM
Means i want to get the variable data that are present in the variable set. What will be the value/code that we will pass for this?
Shoheb
