12-15-2020 04:35 AM
Can anyone suggest me how I can access multi row variable set using REST API explorer.
For single variables, variables.variable_name is working in sysparm_fields. But no luck with multirow variable set.
Request Management
12-15-2020 05:55 AM
Responses below
1. how can I fetch display value of a reference type variable in the multi row variable set.
- not possible as the table only stores sys_id and not display value
2. currently there is a sysparm_limit which is 1 or 10. Can I customize the value. My requirement will exceed 10 for sure.
- this should be fine; when you consume from postman/3rd party tool and don't set the sysparm_limit it should give you all the records
04-06-2021 03:06 AM
to get MRVS data table is different sc_multi_row_question_answer
04-06-2021 03:19 AM
04-06-2021 03:31 AM
like this to get 1 variable value
item_option_new.<variableName>
