Add Affected Configuration Items missing Configuration Class filter
kirkr
Our instance is missing the option to change the Configuration Class when selecting Affected CIs to a Change.
From both the documentation and a personal instance, this should be there to filter on class.
How can I add this to this window?
To navigate to this window, here are the steps:
  • Open any Change with the State of New
  • Open the Affected CIs related list
  • Click the Add button
I found a more 'intense' workaround making sure CI tables show up for Affected CIs.
Edit the AssociateCTToTask Script Include.
Replace line 34 and 35 with these four lines:
//url.set("sysparm_table", latestClassAdded);
//url.set("sysparm_parent_class", parentClass);
url.set("sysparm_table", 'cmdb_ci');
url.set("sysparm_parent_class", 'cmdb_ci');
Now the Class of the original CI will have no impact on the filter, and you'll always have access to all CI classes.
NJ2
Kilo Explorer
Hello Nataraj,
Thanks for the update. how did you get to this tables? can we add tables to this list or it is not possible?
Niranjan.
