Add IF/ELSE condition in Advanced Reference Qualifier
Suryansh Verma
Is it possible to add the IF/ELSE condition in Advanced Reference Qualifier?
On the service portal, I have a Record Producer.
I want to put a condition that if (current.variables.u_name == current.opened_by) then call my script include into reference qualifier else it should work as a simple reference field.
I tried using the below but didn't work for me:
javascript:if(current.variables.u_name == current.opened_by){new ABC().ABCQuery(current.variables.date_day,gs.getUserID())}; else 'active=true';
In attributes field I put ref_qual_elements=u_name;opened_by
Is it possible to achieve this?
Thanks in advance.
You can try below:
Reference Qual: javascript: new ABC().ABCQuery(current.variables.date_day,gs.getUserID(),current.variables.u_name, current.opened_by)
In Script Include only in ABCQuery() function you can add 2 more parameters as above:
function:  ABCQuery( date,userSys_id,name,opened_by)
var sysID;
if (name == opened_by)
<code you have used currently in ABC Query()>
} else
var xyz = new GlideRecord(<table>);
xyz.addActiveQuery();
xyz.query();
while(xyz.next())
sysID.push(xyz.sys_id);
return sysID.join(',');
Something like this.
Please mark this as correct answer and helpful if it resolved, or mark this helpful if this help you to reach towards solution.
Anubhav Ritolia
ServiceNow Rising Star 2023
Reference Qualifier:
javascript:new ABC().ABCQuery(producer.date_day,gs.getUserID(),producer.u_name,producer.opened_by);
Script Include:
var ABC= Class.create();
ABC.prototype = {
    initialize: function() {},
    ABC: function(selectedDate, user,name,opened_by)
        var arr = [];
        var usr = new GlideRecord('sys_user');
        usr.addQuery('sys_id', user);
        usr.query();
        if (usr.next())
if(name!=opened_by)
            var gr = new GlideRecord('x_sosb_fico_time_c_recorded_on_entries');
            gr.addQuery('u_date_day_1', selectedDate);
            gr.addQuery('u_name.user_name', usr.email);
            while (gr.next())
                arr.push(gr.u_ssp_code_1.toString());
            gr.addActiveQuery();
            while (gr.next())
        return "sys_idIN" + arr;
    type: 'ABC'
Try this.
Anubhav Ritolia
Ankur Bawiskar
current.opened_by won't work in ref qualifier
your reference variable is referring to which table?
