Add options based on choices
latha13
In a catalog item i have Multiple Choice field  (New and old choices in multiple choice field)
In that catalog item i have multi row variable set(Accessing) in that there is a field access(Multiple choice field) and choices are Grade1 and Grade2..Now Req is :
Under New -> Accessing(multirow variable set)-> access : Should only have Grade1
Under Old-> Accessing(multirow variable set)-> access  : Should have both Grade1& Grade2( As it is) Mandatory
I tried with on change client script :
g_form.clearOptions('access');
if(newValue=='New')
g_form.addOption('access','Grade1 ');
g_form.removeOption('access','Grade2');
else if(newValue=='Old')
g_form.addOption('access','Grade2');
I just wanted to check-in on this.
If my reply above helped guide you correctly, please mark it as Helpful & Correct.
Thanks!
Priyanka Vasant
Hi Latha,
Find the below link that might help you.
https://community.servicenow.com/community?id=community_question&sys_id=a89e3665db58dbc01dcaf3231f96...
Mark helpful or correct based on impact.
Priyanka A.
