Add Resolution Code to comments
BuriB
Hi all,
how can we add the resolution code in to the comments, so that the creater can the the resolution code inforation in the comments?
Thank you
2 ACCEPTED SOLUTIONS
Hi @BuriB ,
can you try as below
    current.comments = "Resolution code is: " + current.getDisplayValue('resolution_code') + "---->"+ "Resolution Notes is: "+current.getDisplayValue('close_notes');
})(current, previous);
BK
LinkedIn: https://www.linkedin.com/in/bhavyashree-karanth-55032a121
YouTube: https://www.youtube.com/@NowWithBhavya
Hello @BuriB
Since the resolution code is a choice field, therefore number you see is the backend value. To get the display value use getDisplayValue() method.
Here is the updated script:
    var resolutionCodeLabel = current.resolution_code.getDisplayValue(); // Get the label of resolution_code
    current.comments = "Resolution code is: " + resolutionCodeLabel + " ----> " + "Resolution Notes is: " + current.close_notes;
Hope this helps!
"If you found my answer helpful, please like and mark it as an "accepted solution". It helps future readers to locate the solution easily and supports the community!"
Thank You
Juhi Poddar
Thank You!
Juhi Poddar
9 REPLIES 9
hi @Gaurav Shirsat
it looks almost good. I triesd the following:
(function executeRule(current, previous /*null when async*/) {
    current.comments = "Resolution code is: " + current.resolution_code + "---->"+ "Resolution Notes is: "+current.close_notes;})(current, previous);
But by Resolution code it shows the Number not the label. See below
Resolution code is: 31---->Resolution Notes is: Test 7
How i can change to label?
Thank you
Please try current.field_name.getValue()
Sorry I am not expert. Where exactly to but current.field_name.getValue()? Could you please put it in the script? Please 🙂
Hi @BuriB ,
can you try this
BK
Hello @BuriB
Hope this helps!
Thank You
Juhi Poddar
Thank You!
Juhi Poddar
