Adding multi select field to a UI page
samadam
I need to add a multi select field(which lists values from a table) to a UI page and based on the values populate list of records. How can I add the multi select?
Sagar Patro
Hey,
You can use g:ui_slushbucket
Here is a snippet on how you can use it:
	<g:evaluate jelly="true">
   var v_user = new GlideRecord('sys_user');
       v_user.query();
</g:evaluate>
	<div>
<g:ui_slushbucket name="sb" left_header="Left Side" right_header="Right Side">
   <j:while test="${v_user.next()}">
   <option value="${v_user.sys_id}" title="${v_user.name}"> ${v_user.name} </option>
   </j:while>
</g:ui_slushbucket>
	</div>
</j:jelly>
Result:
Mark this as Helpful and Correct if it was.
Sagar Patro
Hey,
       v_user.query();
</g:evaluate>
	<div>
   </j:while>
</g:ui_slushbucket>
	</div>
</j:jelly>
Result:
