‎08-30-2019 06:19 AM
Hi all,
I would like to know why the UI buttons and their functionalities that are configured in ITIL view are not getting reflected in Agent workspace ?
For each and every button we need to go to UI actions and select workspace form button and write a script in workspace client script to make any button work in Agent workspace.
Also would like to know in any of the future release like Newyork or Orlando ,will this remain the same or the buttons we configure in ITIL view will automatically reflect and work in Agent workspace,because it takes lot of effort and time to configure each and every buttons in agent workspace while they already exist in ITIL view.
Any input on this would be highly helpful.
‎09-10-2019 12:57 AM
On creation of a work item, create a scheduled event (let the time be 2 minutes). This will mark the work item as cancelled if the state doesnot change to accepted within 2 minutes.
Then wrte a BR on state change to cancelled
var originalUser = gs.getSession().impersonate("system");
gs.getSession().impersonate(originalUser);
//Closing the interaction on cancellation of work item.
var intr = new GlideRecord('interaction');
intr.get(current.document_id);
intr.setValue('state','closed_abandoned');
intr.update();
//Fetching the conversation details
var conversation = sn_connect.Conversation.get(
intr.channel_metadata_document,
intr.channel_metadata_table
//Send the message to the partner
conversation.sendMessage({
body: gs.getMessage("No agent available"),
system: true
//Close the support channel
new SNC.ConnectListeners().supportSessionClosed(intr.channel_metadata_document);
intr.update();
system: true
‎09-10-2019 07:01 AM
Hi Mrigank Gupta,
Thanks for the response. As I'm working on it for the first time I'm not much familiar with this process. Can u please brief on creating the scheduled event as well and how it gets linked to BR?
Thanks in advance
‎09-16-2019 11:52 PM
Hi Mrigank Gupta,
I would like to know is it possible to configure "Copy Incident" & "Create child incident " in Agent workspace.
Beause i found in docs that "The Copy Incident and Create Child Incident UI actions are not available for workspace."
Does it mean they both are not confgiurable or just not available in Agent workspace.
Docs link : https://docs.servicenow.com/bundle/madrid-servicenow-platform/page/administer/workspace/task/configu...
Awaiting your response.
‎09-17-2019 10:07 PM
You can configure any UI action for workspace view as well.
‎09-18-2019 12:15 AM
Hi Mrigank,
Thanks for the response .
when i put the below script for copy incident in agent workspace ,it did not work .
But the same script works in Itil view .
Not sure what changes we need to do to make it work in agent workspace.
function OnCopyIncidentClick(){
var srcSysId = g_form.getUniqueValue();
var ga = new GlideAjax('IncidentUtils');
ga.addParam('sysparm_name', 'getIncidentQueryParams');
ga.addParam('sysparm_src_sysid', srcSysId);
ga.addParam('sysparm_ui_action', "copy_incident");
ga.setWantSessionMessages(true);
ga.getXMLAnswer(function(queryParam){
if (queryParam) {
var ck;
if (typeof g_ck != 'undefined' && g_ck != "")
ck = g_ck;
var gotoUrl = [];
gotoUrl.push('srcSysID=' + srcSysId);
gotoUrl.push('newSysID=$sys_id');
gotoUrl.push('sysparm_returned_action=$action');
gotoUrl.push('sysparm_ui_action=copy_incident');
if (ck)
gotoUrl.push('sysparm_ck=' + ck);
gotoUrl = 'CopyIncidentRelatedLists.do?' + gotoUrl.join('&');
var form = cel('form', document.body);
hide(form);
form.method = "POST";
form.action = g_form.getTableName() + ".do";
if (ck)
addParam(form, 'sysparm_ck', g_ck);
addParam(form, 'sys_id', '-1');
addParam(form, 'sysparm_query', queryParam);
addParam(form, 'sysparm_goto_url', gotoUrl);
form.submit();
}else{
g_form.addErrorMessage("Failed to copy incident");
function addParam(form, name, val) {
var inp = cel('textarea', form);
inp.name = name;
inp.value = val;
Thanks in advance
