‎04-12-2021 06:03 AM
I am using the below code in a Onsubmit catalog client script to show an alert for attaching a file before submitting the ticket in the portal.
Script:
function onSubmit() {
try { //Works in non-portal ui
var attachments = document.getElementById('header_attachment_list_label'); //Line3
if (attachments.style.visibility == 'hidden' || attachments.style.display == 'none' ) {
alert("Please attach file before submitting.");
return false;
} catch(e) { //For Service Portal
var count = getSCAttachmentCount();
if(count <= 0) {
return false;
According to Best Practice, we will not be using DOM manipulation , so I need to replace the code. Can I get the alternative solution for the line 3 in the above script by not breaking the existing functionality.
Thanks in Advance,
Shilpa.
Service Catalog
‎04-16-2021 03:59 AM
I haven't tried with this
let us know if that works well
var attachments = g_form.getFormElement('header_attachment_list_label');
‎04-16-2021 04:02 AM
Hi
Ya, I have already tried and it is working with this line Ankur.
I thought of checking with you if u have tried earlier.
Shilpa
‎04-16-2021 04:04 AM
then you should be good here.
Please mark my response as correct and close the question
‎04-16-2021 04:08 AM
Hi
yes Ankur, I have marked it.
I have one more question if u can answer..
which code can I replace the below bold code.(we should not use DOM)
function getParmVal(name){
var url = document.URL.parseQuery();
if(url[name]){
return decodeURI(url[name]);
else{
Shilpa
‎04-16-2021 04:11 AM
use top.location.href to get the URL
to get parameter value
var glideURL = new GlideURL();
glideURL.setFromCurrent();
var comp = glideURL.getParam("sysparm_Comp");
‎04-16-2021 04:13 AM
Hi
Below is the complete code, where can I modify exactly
function onLoad() {
//Populate the variables with the parameters passed in the URL
//Use the 'getParmVal' function below to get the parameter values from the URL
var sd = getParmVal('sysparm_short_descr');
var ds = getParmVal('sysparm_full_descr');
g_form.setValue('short_descr',sd);
g_form.setValue('full_descr',ds);
if(url[name]){
else{
Shilpa.
