Any advice on using duration field for closed problem tasks
04-25-2025 12:28 PM
Help - trying to use the Duration field on Closed Problem Tasks.
Created to Closed, but nothing is showing in the Duration field.
What am I missing?
04-25-2025 02:26 PM
Duration is a field whcih is on the task table and here are a few details
https://www.servicenow.com/community/csm-forum/catalog-task-duration-business-rule/m-p/403227
04-25-2025 11:52 PM
Hello @JohnEJasinski ,
Using the Duration and especially the Business Duration fields is no longer recommended, as SLAs provide a better alternative that gives more control over the schedules and time zones involved in the calculation.
If you want to go ahead with using the duration fields you can create a Business Rule as shown below:
Advanced Script:
current.business_duration = gs.calDateDiff(current.opened_at.getDisplayValue(), current.closed_at.getDisplayValue(), false);
current.calendar_duration = gs.dateDiff(current.opened_at.getDisplayValue(), current.closed_at.getDisplayValue(), false);
})(current, previous);
Robert
