Approval Flow for Change Management
Aashish_D
Hello All,
Can anyone explain how the OOTB approval flow is for the normal Change Requests?
As per my understanding:
  1. If the risk is low then Approval goes to Assignment group manager and then assignment group members.
  2. If the risk is moderate/ high then the Approval goes to CAB and Assignment group manager.
Is this flow suitable for most IT/ Infra related Change Requests? Or is their any other widely used approval flow which suits most IT/ Infra related changes.
ADD
J Siva
HI @Aashish_D
We don't have a defined approval flow. It varies based on client.
In general to implement he change, the requetser or the implementer must get as approval from the system owners/custodians, then peer approval (Tech leads) and at the end if required CAB approval. This flow covers all the necessary approval.
Ops approval (system owner) -> Tech approval (Tech leam leads) -> CAB (If required)
Hope this helps.
Reagrds,
Siva
Dr Atul - LNG
Hi @Aashish_D
  1. If the risk is low then Approval goes to Assignment group manager and then assignment group members. ---> You need to check in the flow as well as the approval policy to see the conditions under which the approval is defined.
  2. If the risk is moderate/ high then the Approval goes to CAB and Assignment group manager. -->
    If the risk is high and the change type is normal, then yes, it goes to CAB, not the assignment group, and that is the authorized state.
    In the out-of-the-box way:
    A normal change has two levels:
    • Assess – Goes to the assignment group
    • Authorize – Only CAB (Now, it can also be based on Risk)
You can test the same in PDI.
https://youtu.be/YNT-kaQOxDs
https://youtu.be/Ke6JaBiNd6Q
https://youtu.be/ahJoO5sKE9g
Disclaimer: These videos are from my training batch. These videos did not promote any ServiceNow Sales pitch or marketing. These videos are only for knowledge purposes. LinkedIn:https://www.linkedin.com/in/atulgroverservicenowconsultant Redistribution or copying of functionality is not allowed!
WithMe #ServiceNow # ChangeManagement Learn Change Management , Process Flow and OOTB Demo LinkedIn:https://www.linkedin.com/in/atulgroverservicenowconsultant Redistribution or copying of functionality is not allowed!
