04-13-2022 03:54 AM
Need help on the below requirement
I have created notification on sysapproval_approver table . The conditions are the
Approval for. Task Type---> Is ----> Request Item
I the body of the notification i want to add the Request information that means the approval is happen for that request
I need to add that request information in the body
Thanks in advance 🙂
04-14-2022 11:28 PM
Glad to know that my script worked.
use template.print('<br/>') to print in new line
✨ Certified Technical Architect || ✨ 9x ServiceNow MVP || ✨ ServiceNow Community Leader
04-14-2022 05:53 AM
if it didn't work then you can use email script and print it
then include that email script in email body
${mail_script:mailScriptName}
var gr = new GlideRecord("sc_req_item");
gr.addQuery("sys_id", current.sysapproval);
if (gr.next()) {
template.print(gr.request.number);
04-14-2022 07:11 AM
Hi Ankur,
I called in the notification body but not getting output and for your kind information the same code i have tested in the backgroud script getting error like ---->
Cannot read property "sysapproval" from null Caused by error in script at line 2
Please help me on this.!
Thanks 🙂
04-14-2022 10:29 AM
script will work if your notification is on sysapproval_approver table
04-14-2022 08:10 PM
04-14-2022 08:19 PM
your question is for showing REQ number but you are doing preview of CHG record
Can you test it well?
share your email script as well
