Assignment group is not showing in Task Assessment Details
Sriram Pusuluri
Hi Team,
in Task Assessment Details  in dev assignment groups are showing, However in prod assignment groups is showing as empty.
below is dev
prod:
Assignment group is same
for Incidents Assignment group is populating, For Request or Requested Item Assignment group is not populating
@Ankur Bawiskar
14 REPLIES 14
Ankur Bawiskar
@Sriram Pusuluri
did you check in list view of that table the assignment group is populated or not?
Did you check the view which is shown to user has that field in it?
what debugging did you do from your side?
@Ankur Bawiskar It is only showing for Incident table. For Request it is showing as empty.
for Request:
It is not working for Request only
@Sriram Pusuluri
did you check that REQ record has assignment_group populated or not?
the database view simply pulls it from that Task based record
If the group is empty in REQ then it won't be shown
Hi @Ankur Bawiskar
For Request Assignment group is empty.
@Sriram Pusuluri
since that field is empty it might not be shown on form when you open database view record
did you try populating the group and then reload and see if it shows?
