Assignment group is not showing in Task Assessment Details
Sriram Pusuluri
Hi Team,
in Task Assessment Details  in dev assignment groups are showing, However in prod assignment groups is showing as empty.
below is dev
prod:
Assignment group is same
for Incidents Assignment group is populating, For Request or Requested Item Assignment group is not populating
@Ankur Bawiskar
14 REPLIES 14
For in dev it is showing assignment group for Request table
For Prod it is showing as empty
@Sriram Pusuluri
So you need to debug why REQ is not getting with group populated?
check in DEV which BR or logic does that and it might be breaking in PROD
@Sriram Pusuluri
I could see the default view does have the Assignment Group in it OOTB and the task also has it
Not sure why it's not shown on form
Ankur Bawiskar
@Sriram Pusuluri
task_assessment_detail is a database view which joins 4 tables
are you sure your user has read access to that group field on task table?
nayanmule
Check the dictionary field for the Assignment group if it has any Default values defined or any reference qualifier.
Check if the sys_ids of the groups match or not in dev and prod.
Nayan
