Assignment lookup rule is not working
Hello folks,
I created one new assignment rule on Incident form and its work fine . But now i am getting confusion on below criteria .
I would like to assign an incident to particular group based on Category type and it should depends on Subcategory type . So i have modified existed Data Lookup Definition   as below .
Defined matcher field defination on only Category type and setter field definition on assignment_group       , and i have created an assignment lookup rule when category is network automatically ticket value populate on assignment_group is network .
Now my query is like this rule in not working when ever i change category type to network its not assigning . So cant we change any field value based on only category type without including Subcategory . And this is the only rule exists on Incident table so no chance or order dependency .
Thanks in advance .
Michael Fry1
On the Setter Field Definition, if Always replace is false, it won't under the group when category changes. If true, it will replace.
If changes are made on the form that match a different assignment rule, Always replace determines if the Assignment group should be updated or not.
