ATF - How to Set Variable Value for Choice Variable with Choices Added via Client Script
symonflores_23
I'm trying to set variable values for a Select Box variable. However, the choices are added via a catalog client script. How can I select a value for this variable and proceed with the submission if the choice does not appear in this step?
Ankur Bawiskar
@symonflores_23
you must have created choices in question_choice table for that variable?
If not then it won't come in your Step when you set the variable value.
question choice table is empty and I am filling dynamic values through client scripts but in atf its considering question choice list and I am unable to set value as it is empty. Any other alternative way ??
Unless you also run a script in ATF, unfortunately that's the limitation of the ATF.
