Auto close resolved incidents business rule and scheduled item is not working as expected
Roxi1
We have defined business rule, scheduled item, and system property to auto close the particular resolved incidents, but not closing the incidents and not getting any logs in system logs. can someone please help on it. here am pasting BR, schedueld item, and system property. for testing purpose we can not wait for days. is there any way that we can set some minutes.
after BR:
// Add your code here
autoCloseIncidents();
function autoCloseIncidents() {
var ps = gs.getProperty('glide.ui.securityincidentautoclose.time');
var pn = parseInt(ps);
var queryTime = new GlideDateTime();
queryTime.addDaysUTC(-pn);
//queryTime.addSeconds(-pn);
if (pn > 0) {
gr.addEncodedQuery('category=IT Security^u_security_incident_stateNOT INproposed,accepted,rejected^incident_state=6');
// gr.addQuery('sys_updated_on', '<', queryTime);
while(gr.next()) {
gr.state = 7;
gr.setLimit(3);
gr.comments = 'Incident automatically closed after ' + pn + ' days in the Resolved state.';
gr.active = false;
gr.work_notes="Auto closed resolved incidents through Business rule";
gr.closed_by = gr.resolved_by;
gs.log("The resolved incidents are closed");
gr.update();
scheduled item:
System Property:
the BR runs based on scheduled trigger
If the OOB one runs fine then your should also work fine
suvro
Looks fine
gr.setLimit(3); should be fore the loop
suvro
I hope Business Rule name matches the script name below
Try to keep logs in between the code, so that you get to know, where it is getting stuck
Roxi1
it seems no log is getting generated in system logs, means the BR itself is not triggering. can you please help me why this BR is not getting triggered
Make the name of the business rule without any spaces, then it will trigger
