Auto populate catalog item field from client script
Kai Tingey
Hi All
i'm trying to write a client script for a catalog item to populate a reference field, based on another reference field. Basically i want to take the selected user in the u_requested_for field, look up their computer from the cmdb_ci_computer table, and then populate the u_cmdb_ci field on the form with that value.
I have:
(on change client script, based on u_requested_for variable)
var user = g_form.getValue('u_requested_for');
var gr = new GlideRecord('cmdb_ci_computer');
gr.addQuery('assigned_to', user);
if(gr.next()){
g_form.setValue('u_cmdb_ci',gr.sys_id);
a variation of this script works elsewhere, where we are populate an incident record's ci value based on who is in the caller field. however on this catalog item when trying to do it with the form values it's not working. In that case it's part of the record producer so clearly i'm doing it wrong here or not understanding the difference in how scripts work in different places.
any help to steer me in the right direction would be appreciated.
Lets do GlideAjax then 🙂
Add this onChange Script in the Requested by:
	var gajax = new GlideAjax('CMDBUtils');
	gajax.addParam('sysparm_name', 'getCIDetails');
	gajax.addParam('sysparm_user', newValue);
	gajax.getXML(setCIDetails);
	function setCIDetails(serverResponse) {
		var cc = serverResponse.responseXML.documentElement.getAttribute("answer");
		g_form.setValue('computer', cc);
And this script include:
var CMDBUtils = Class.create();
CMDBUtils.prototype = Object.extendsObject(AbstractAjaxProcessor, {
	getCIDetails: function () {
		var usr = this.getParameter('sysparm_user');
		var gr = new GlideRecord('cmdb_ci');
		gr.addQuery('assigned_to',usr);
		if (gr.next()) {
			return gr.sys_id;
		else {
			return '';
	type: 'CMDBUtils'
Let me know how you go.
Raf
11 REPLIES 11
I see, you best bet then if an onChange script. the only caveat is when a user is assigned to multiple CI's, which then do you use as default?
Can you try this on your onChange Script under Requested For field:
	if (isLoading || newValue == '')
	gr.addQuery('assigned_to', newValue);
	gr.addQuery('sys_class_name', 'cmdb_ci_computer');
	if(gr.next()){
no joy unfortunately.
		if (gr.next()) {
			return gr.sys_id;
		else {
			return '';
	type: 'CMDBUtils'
Raf
thank you so much, that got it! just needed to make some tweaks to the form values for my variable names.
