Auto populate watchlist
rakesh8
Hi guys,
I got two variables in service catalog,
incident created: ref type
watchlist: list collector
I want to autopopulate the watchlist based on the incident record that i choose. Can i get some hints or sol for this
thank you
Hi @rakesh8 ,
Try the below client script code on change of your incident variable:
var inc= g_form.getReference('your_incident_variable_name', populateWatchList);
function populateWatchList(inc) {
       g_form.setValue('your_watch_list_variable_name', inc.getValue("watch_list");
I hope this help.
Please mark this helpful if this helps and Accept the solution if this solves your issue.
Kamlesh
9 REPLIES 9
@rakesh8  I am glad, it helped.  Below inline is the explanation of code used.
var inc= g_form.getReference('your_incident_variable_name', populateWatchList); //Get the reference of the selected incident record Asynchronously and pass it to the  'populateWatchList' callback function
       g_form.setValue('your_watch_list_variable_name', inc.getValue("watch_list"); //Inside the callback function we are retreiving the value of the selected incident's watchlist field and populating the watchlist variable of the catalog item.
I hope this helps.
Kamlesh
Thank you so much ^^
@rakesh8
1.Create an onchange client script on change of incident.
2. Use below script:
var incRecord = g_form.getDisplayBox('incident backend name').value;
g_form.setValue('watch_list' backend name', incRecord );
rakesh8
Its not working @Manal Aquil . i applied what you said in the catalog client script with on change variable as incident created
@rakesh8 I don't see you are using below script :
var incRecord = g_form.getDisplayBox('incident_created').value;
g_form.setValue('watchlist', incRecord );
 Mark helpful if it works
