Automatically add role to group via script
ejaram
Kilo Expert
I am working on a script to create a group, add users to the group, set the manager, and add a role to the group.
I have the group creation, user add, and manager set working fine however I cannot get the role portion to work. I am not sure how to manipulate the 'sys_user_group' table to add the role to the group (since the 'Roles' is a related list on the table).
Anyone have any experience with this or how to go about it?
Thanks in advance,
Evan
TJW2
Mega Guru
The 'sys_group_has_role' table is where this information is stored. You will need to store the reference to the Group and the reference to the Role in this table.
kevinanderson
Giga Guru
This worked for me (transaction cancelled for very long lists, may require multiple runs):
var groups=[
'<group 1 name >',
'<group 2 name >',
'<group 2 name >',
'<group 4 name >',
// 1. get sys id of item role
var gr = new GlideRecord('sys_user_role')
gr.addQuery('name' , 'itil');
if (gr.next()){
      // 2.   loop over list of groups
      for (var i=0; i < groups.length; i++){
              var gr2 = new GlideRecord('sys_user_group');
              gr2.addQuery('name' , groups[i]);
              gr2.query();
              while (gr2.next()){
                        // 3. get group sys id
                        // update group roles table swith group sys id and role sys id
                      var gr3 = new GlideRecord('sys_group_has_role');
                      gr3.addQuery('group', gr2.sys_id);
                      gr3.addQuery('role', gr.sys_id);
                      gr3.query();
                      if (gr3.getRowCount() == 0){
                              var gr4 = new GlideRecord('sys_group_has_role');
                              gr4.initialize();
                              gr4.group = gr2.sys_id;
                              gr4.role = gr.sys_id;
                              gr4.inherits = true;
                              gr4.insert();
                              gs.print('added record for '+gr2.name)
                      else{
                            gs.print('existing record found for '+gr2.name)
