Autopopulate Select box variable based on string variable
JRY
Mega Guru
Hello All,
I'm trying to populate a selectbox variable based on a single line text field. As we can see in the below image, I'm trying to autopopulate dropdown choice based on a single line text field value. As you can see in the below image, but below script, it's not working as expected. Can someone help me with corrections to the script?
LAN ID == Single line Text variable
Domain == Dropdown/selectbo
    var lanId = g_form.getValue('lan_id');
    lanId = ["ACCPT", "AF", "AP", "EA", "NA", "SA", "UPSTREAMACCTS"];
    if (lanId.indexOf('ACCPT') !== -1) {
        g_form.setValue('domain', 'ACCPT');
    } else if (lanId.indexOf('AF') !== -1) {
        g_form.setValue('domain', 'AF');
    } else if (lanId.indexOf('AP') !== -1) {
        g_form.setValue('domain', 'AP');
    } else if (lanId.indexOf('EA') !== -1) {
        g_form.setValue('domain', 'EA');
    } else if (lanId.indexOf('NA') !== -1) {
        g_form.setValue('domain', 'NA');
    } else if (lanId.indexOf('SA') !== -1) {
        g_form.setValue('domain', 'SA');
    } else if (lanId.indexOf('UPSTREAMACCTS') !== -1) {
        g_form.setValue('domain', 'UPSTREAMACCTS');
JRY
Murthy Ch
Hi @JRY
Can you try this:
    //lanId = ["ACCPT", "AF", "AP", "EA", "NA", "SA", "UPSTREAMACCTS"]; //commented this line
    if (lanId.indexOf('ACCPT') >-1) {
    } else if (lanId.indexOf('AF') >-1) {
    } else if (lanId.indexOf('AP') >-1) {
    } else if (lanId.indexOf('EA')>-1) {
    } else if (lanId.indexOf('NA') >-1) {
    } else if (lanId.indexOf('SA') >-1) {
    } else if (lanId.indexOf('UPSTREAMACCTS') >-1) {
Hope it works
Murthy
Hi Murthy,
I have tried your script as you can see in below image it's taking wrong choice
Hi @JRY
Yes it's because it is satisfying the below else if condition before going to the last else if
As your text contains the EA in the LAN ID the EA option is populated.
So you just need to update the condition in the else if where it has to be unique in the indexOf
Hope it helps..
Note: No issues in the logic.
Murthy
Thanks, I have modified the value now it's working fine.
JRY
Saurav11
Are you trying to set a single value or a choice of values in the dropdown:-
If it is a choice of value add all the options at top i.e by using :-
g_form.addOption('domain','ACCPT','ACCPT',1); // do it for all options
and then in the if statement just remove the option using:-
g_form.removeOption('domain','ACCPT');
Please mark my answer as correct based on Impact.
Hi Saurav,
I tried the below script as you suggested, but it didn't work. capturing the wrong value. Can you please tell me what went wrong with the below script?
        g_form.addOption('domain', 'ACCPT', 'ACCPT', 1);
        g_form.addOption('domain', 'AF', 'AF', 2);
        g_form.addOption('domain', 'AP', 'AP', 3);
        g_form.addOption('domain', 'EA', 'EA', 4);
        g_form.addOption('domain', 'NA', 'NA', 5);
        g_form.addOption('domain', 'SA', 'SA', 6);
        g_form.addOption('domain', 'UPSTREAMACCTS', 'UPSTREAMACCTS', 7);
    if (lanId.indexOf('ACCPT')) {
        g_form.addOption('domain', 'ACCPT', 'ACCPT');
        g_form.removeOption('domain', 'AF');
        g_form.removeOption('domain', 'AP');
        g_form.removeOption('domain', 'EA');
        g_form.removeOption('domain', 'NA');
        g_form.removeOption('domain', 'SA');
        g_form.removeOption('domain', 'UPSTREAMACCTS');
    } else if (lanId.indexOf('AF')) {
        g_form.addOption('domain', 'AF', 'AF');
        g_form.removeOption('domain', 'ACCPT');
    } else if (lanId.indexOf('AP')) {
        g_form.addOption('domain', 3, 'AP');
    } else if (lanId.indexOf('EA')) {
        g_form.addOption('domain', 'EA', 'EA');
    } else if (lanId.indexOf('NA')) {
        g_form.addOption('domain', 'NA', 'NA');
    } else if (lanId.indexOf('SA')) {
        g_form.addOption('domain', 'SA', 'SA');
    } else if (lanId.indexOf('UPSTREAMACCTS')) {
        g_form.addOption('domain', 'UPSTREAMACCTS', 'UPSTREAMACCTS');
