Call a system property from flow designer
Jyotsna Behera
How can i check condition of system properties in flow design? i have a system properties that contains list of sys_id of groups.A approval will skip if value of variable (contain group)matches with system properties.
OlaN
Tera Sage
In Flow designer a system property is fetched with the Look up record action, just like any other record you would want to retrieve.
Example below:
dmathur09
Hi Jyotsna,
You can use the OOB function gs.getProperty('assignment_group'); This will give you the sys_id of the group A that you have stored in sys_properties table.
Deepankar Mathur
OlaN
Tera Sage
Example below:
Seems like the table System Property [sys_properties] is no longer available in Flow action Look Up Record(s), at least in Vancouver version.
I wanted to get a properties value, but it doesn't seem to be possible without javascript (gs.getProperty()).
Anyone else has this issue?
Just tested this on my PDI (Vancouver), no issues.
Only thing I can think of, is checking this system property:
sn_flow_designer.allowed_system_tables
Link to KB
