Call a system property from flow designer
Jyotsna Behera
How can i check condition of system properties in flow design? i have a system properties that contains list of sys_id of groups.A approval will skip if value of variable (contain group)matches with system properties.
OlaN
Tera Sage
In Flow designer a system property is fetched with the Look up record action, just like any other record you would want to retrieve.
Example below:
You are correct. I didn't realize that system tables need to be added separately to this property.
I only had sys_attachment,sys_data_source,sys_flow_data there. Thank you!
