Can you help me for write script
IshwarR07
Requirements - create entity field in hardware table choices: asia,  europe. create 2 location and based on those two locations if location A is selected then entity should automatically populated as Asia and if location is B then entity should populate as Europe. Whenever new record create or update or insert through transfer map
var lName = g_form.getDisplayValue('location');
if(lName == 'A'){
    g_form.setValue('u_entity','Asia');
}else if(lName == 'B'){
    g_form.setValue('u_entity','Europe');
}else{
    g_form.clearValue('u_entity');
these script is not working instead of these what can i write.
Mark Manders
Add the entity to the location record and use the dotwalked field from the location table on your target record.
Mark
Ankur Bawiskar
@IshwarR07
that's not how you get display value of reference field.
update as this, ensure you use correct choice value to set the entity and don't use choice label
     var lName = g_form.getDisplayBox('location').value;
     if (lName == 'A') {
         g_form.setValue('u_entity', 'Asia');
     } else if (lName == 'B') {
         g_form.setValue('u_entity', 'Europe');
@IshwarR07
Hope you are doing good.
