Cant post Work Notes
Gerard9
Giga Contributor
We built a number of new Service Requests, that create RITMs and SCTasks.  But for some reason we cant post 'Work Notes' on either the RITM or SCTask.  I have looked everywhere i can think of that might prevent being able to post.
I can type into the field, but it wont post.  I would welcome any ideas or suggestions that might help resolve the issue.
You are very welcome Gerard! 🙂
Thanks for marking answers as Helpful, that really helps! Can you also mark one as Correct? That will close the thread.
15 REPLIES 15
Willem
Tera Sage
Hi Gerard,
You need the personalize_form or personalize_list role to do the following:
Customize the fields that appear in the activity filter
Gerard9
Giga Contributor
Thanks Willem,
I have added those roles and it still isnt working.  I have even re-added the activity filter.  Thanks for your help.  There must be something weird preventing it.  I will keep digging.
Cheers
Can you check if there is an onload client script or UI Script that might hide this/cause this to not show?
Gerard9
Giga Contributor
Thanks Willem,
there is nothing i can see.  and i did a side by side comparison with other requests that are working.
Is there a difference in the workflow attached?
