Catalog Client Script is not working
12-18-2024 10:50 AM
Hello Everyone
Below Catalog Client script is not working to Populate the Word Count. Could someone help me on this.
if (isLoading || !newValue) {
var kbaRecord = new GlideRecord('kb_knowledge');
if (kbaRecord.get(newValue)) {
var title = kbaRecord.getValue('short_description');
var text = kbaRecord.getValue('text');
var combinedText = title + " " + text;
var wordCount = combinedText.trim().split(/\s+/).length;
g_form.setValue('word_count', wordCount);
g_form.showFieldMsg('word_count', 'Word count: ' + wordCount, 'info');
12-18-2024 07:42 PM
I agree with Brad here. Please use GlideAjax or getReference with callback
12-18-2024 07:51 PM
Hi @Vamsi26 ,
You need to make Ajax call to get the count.
Create script include and call that from your catalog client script.
Do like below.
Client script code
var ga = new GlideAjax('KBWordCount');
ga.addParam('sysparm_name', 'getWordCount');
ga.addParam('sysparm_kbId', newValue);
ga.getXMLAnswer(function (response) {
var result = JSON.parse(response);
if (result.error) {
g_form.showFieldMsg('word_count', result.error, 'error');
g_form.setValue('word_count', result.wordCount);
g_form.showFieldMsg('word_count', 'Word count: ' + result.wordCount, 'info');
Script include code:
getWordCount: function (kbId) {
var result = {};
if (kbaRecord.get(kbId)) {
var title = kbaRecord.getValue('short_description') || '';
var text = kbaRecord.getValue('text') || '';
result.wordCount = combinedText.trim().split(/\s+/).length;
result.error = 'Knowledge article not found.';
return JSON.stringify(result);
Make sure script include is checked for client callable.
12-18-2024 09:02 PM
Hello @Vamsi26,
GlideRecord is a server-side script, and while it is possible to use it in a client script, doing so can lead to performance issues. Additionally, it is not considered a best practice to use GlideRecord in client scripts.
1. In your case, you can use GlideAjax along with a script include to address the problem and ensure your code executes faster.
2. Also, please make sure that you are using the correct field name, which is 'word_count':
I hope this helps!
