07-11-2017 12:32 PM
Hi everyone,
I have the following Catalog Client Script to make a field mandatory if a user has a specific role.
function onLoad(){
var user = g_user.hasRole('it_security');
if(user == true){
g_form.setMandatory('risk_comments_1',true);
g_form.setMandatory('sec_rating_1',true);
For some reason it is not making the field mandatory even though the user does have the role. I have another script to make the same fields read only if the user does not have that role, and that one is working just fine.
Any help is appreciated!
07-11-2017 02:01 PM
ok the first thing i would do is disable all other client scripts and ui policies on the item... then see if it works right.. if so you have a conflict..enalble them one at a time and see which one breaks your client script and why.
07-11-2017 12:44 PM
you missed "}" at line 9
- function onLoad(){
- var user = g_user.hasRole('it_security');
- if(user){ // you are getting true so no need to do compare
- g_form.setMandatory('risk_comments_1',true);
- g_form.setMandatory('sec_rating_1',true);
07-11-2017 01:05 PM
That was just a copy\paste error. It's correct in the actual script. Thanks!
07-11-2017 01:15 PM
- if(user) // you are getting true so no need to do compare
- //g_form.setMandatory('risk_comments_1',true);
- alert('it is working');
- else
- alert('not working');
- //g_form.setMandatory('sec_rating_1',true);
try now just validate if it is giving alert() or not
