catalog item variables not showing in catalog task
‎07-31-2018 05:54 AM
Hello People,
We have added a catalog item using the ItemDesigner and then added some variables using the Maintain Items.
When i open the item from the maintain items, i see the "Item Designer Workflow" in the Workflow field as read-only.
The Variables defined as below
The RITM generated upon placing the order request is as below, to which a task gets auto generated -
Upon viewing the created Task, the variables value i.e. test for the field abc defined while ordering the catalog item isn't showing in the task form
Any suggestions, how we can bring in the Variable values in the Task form as it appears in the RITM would be much appreciated..!!? TIA..
~Somujit
Service Catalog
‎08-01-2018 12:22 AM
Hello Satheesh,
I am using the default "Item Designer Workflow" and i seen no Task Block in the default Workflow.
~Somujit
‎08-01-2018 09:52 AM
Did you try making that variable Global in your catalog item?
‎08-01-2018 10:08 AM
‎04-01-2019 02:40 PM
I have the same issue, cat item created via item designer, none of the variables appear on the generated catalog task. All the previous solutions provided in this scenario only apply to a normal workflow and not one created via the item designer. I'm just trying to work out is there any value doing item creation via this designer method.
My example, I've created an item with 5 variables, 1 approval & one task. This auto generates 4 workflow and none contain a task that I can add the missing variables too.
1.
2.
3
4
‎04-01-2019 07:00 PM
Since you are using Item Designer, we might not be able to use the flexibility of workflows to add variables in the tasks created during the process as there is only one workflow linked to item designer which dynamically creates all the tasks specified in the Task plan of item designer.
OOB, variables in tasks are shown using the Variable editor. Variable Editor fetches the variables data from sc_item_variables_task table for Tasks and sc_item_option_mtom for Request Items. Since we are not linking any variables to the task created by the Item designer, there is no data present in sc_item_variables_task table for the task created by Item designer.
Workarround:
create an Insert business rule at catalog Task level and check if the Request Item.Catalog Item.Workflow == Item Designer Workflow. If so, then run the following script to link the variables to the catalog task.
var item_var = new GlideRecord('sc_item_option_mtom');
item_var.addQuery('request_item',current.request_item);
item_var.query();
while(item_var.next())
gs.log(item_var.sc_item_option.item_option_new.question_text);
var task_var = new GlideRecord('sc_item_variables_task');
task_var.initialize();
task_var.task=current.sys_id;
task_var.variable=item_var.sc_item_option.item_option_new;
gs.log(task_var.insert());
Hope this will help resolve your problem and achieve what you are looking for.
