Change and Problem is missing in application menu
As I was exploring the Australia version, I was unable to find the Change and Problem applications in the Filter  Navigator. I also checked the Application Menu table (sys_app_application), but I could not find any records for Change and Problem.
Is this a known issue or do I need to make any configurational changes?
9 REPLIES 9
Hi @glideFather,
Thanks for the suggestion. We verified the roles and confirmed the affected users already have the required access, including change/problem related admin roles.
The issue is occurring specifically in the Application Navigator where the Change and Problem modules are not visible, while Incident is available. We also tested with admin access and observed the same behavior
Tanushree Maiti
Hi @Community Alums
As per KB: KB0011096 Cannot find an application record in the application menu module
Validate this one:
Resolution
To view and reactivate an inactive application record:
1. Navigate to System Definition > Application Menu.
2. Locate the Active = true filter at the top of the list.
3. Click the X icon next to the Active = true filter to remove it. All application records, including inactive ones, will now be displayed.
4. Search for and open the desired application record.
5. Set the Active field to true.
6. Click Save to apply the change.
Also refer: KB0747639 User cannot see application due to active override in place
Devi
while clicking on create new change in australia version I am getting this page not able to create the change. I am having change models but it is not showing up here. Please let me know what configurations i have to do
Jaipal Reddy
The Parent Application Menu is missing and also the mappings to the sub menu's. I have used Now Assist to build them back. Just run the background script attached to them back. Make sure to refresh the page after running the BG Script.
