Changing Field Style for Problem Tasks if due date is passed
Joe Taylor
Giga Guru
I'm trying to change the font color of the due dates in the list view of PTASKS if the due date is past, but no matter what I try it doesn't seem to work.
Here's what I have now:
Table: Problem Task [problem_task]
Field Name: Due date
Value: javascript:gs.dateDiff(current.due_date.getDisplayValue(),gs.nowDateTime(),true) <  0 ;
Style:  color:red;
What am I doing wrong?
Also, where can if find a comprehensive list of styles  (colors, background, font sizes, etc.) ?
If its exceeding the field limits then you can put the code in script include and from there return true/false.
Like for yellow you could do this.
1) Create a script include (I named mine as TestDate)
2) Then call the script include (and function - which I named isYellow) from Styles
Could you please mark my answer as correct? It gives me few points on community.
Thank you!
-Tanaji
Please mark reply correct/helpful if applicable
22 REPLIES 22
Joe Taylor
Giga Guru
Thank you so much!
Everything is working exactly as I was hoping for now.
Red, Yellow and Green dots are showing up on Task View and problem view with corresponding due dates.
Here's what my 3 styles finally look like now:
Table: Task
Field Name:  Due Date
Value: javascript: var answer = (current.due_date.getDisplayValue() <= (new GlideDateTime().getDisplayValueInternal())) && current.sys_class_name == 'problem_task' && current.state  < '3' ; answer;
background-color: red
Table: Task
Value: javascript: var answer = (current.due_date.getDisplayValue() > (new GlideDateTime().getDisplayValueInternal())) && current.sys_class_name == 'problem_task' && current.state  < '3' ; answer;
background-color: yellow
Table: Task
javascript: var gdt = new GlideDateTime(); gdt.addDays(7); var answer = (current.due_date.getDisplayValue() > gdt.getDisplayValueInternal()) && current.sys_class_name == 'problem_task' && current.state < '3' ; answer;
background-color: green
Couldn't use your suggest value for "yellow" since it was too long to fit into the window.
But my three styles seem to be evaluated correctly anyway.
Thanks again
Thank you!
-Tanaji
lasse3
Giga Guru
It is highly recommended not to use display values, when doing scripting as this may give you unexpected results depending on display settings which may vary depending on customer regional settings etc. Instead use compareTo or numeric values when comparing dates. Here is an example:
javascript: var answer = ((new GlideDateTime(current.due_date)).getNumericValue() <= (new GlideDateTime().getNumericValue())); answer;
I hope this will help someone out there 🙂
