Check boxes set as true based on question choices.
sivananda80
Now I am working catalog item, In catalog having 20+ check boxes .Based on question choices I need auto check(true) the check boxes.
For this I wrote client script. But  when I am selected question choice the only one check boxes. its first check box.As for attachement
But I wrote client scripts for 2 nd 3rd check boxes.
I need get auto check the based on script condition .
Can you refer attachments for reference
Can you please help me on that.
Thank you.
Hi Jan,
Thank you for response,
I am using this code also.
But getting first check as true. Even  I am giving the condition for second check box its getting as a true for 1st check box only
Thank you
Thank you
ersureshbe
Can you use catalog UI Polices to get this instead of writing the client script.
Please mark as helpful if it helped.
Suresh.
Suresh.
