check if roles from gliderecord output are in array
JoaoV
Hi guys,
I need to check if the roles from a gliderecord output are inside my array.
Example:
var gr = new GlideRecord("sys_group_has_role");
gr.addQuery("group", current.sys_id);
while (gr.next()) {
     !!!CHECK if gr.role is inside my arr!!!
I have tried to add the array directly to the query but it is useless because it checks if there are ocurrences but I will not know which one matches and which one doesn't
I have tried indexOf but it is not working for me:
while (gr.next()) {
     if (arr.indexOf(gr.role)) {
Any tips?
2 ACCEPTED SOLUTIONS
RaghavSh
 if (arr.indexOf(gr.role)>-1) {
} // if your array has sysid of roles.
if (arr.indexOf(gr.role.name)>-1) {
} // if your array has name of roles.
Raghav
MVP 2023
LinkedIn
Thanks @RaghavSh it works great. Before of that I had to convert the array to string!
Hi @JoaoV,
I would suggest to get unique elements before passing it to query.
var arr = ["admin", "test", "impersonator", "admin", "itil"];
var uniqueArray = [];
var arrUtil = new global.ArrayUtil();
uniqueArray = arrUtil.unique(arr);  // get Unique elements
for(var i = 0; i < uniqueArray.length; i++){
gr.addQuery("group", "725eb7f4db9532000454f1351d96198c");
gr.addQuery("role.name", uniqueArray[i]);
gs.info(gr.getRowCount());
while (gr.next()) {
//     !!!CHECK if gr.role is inside my arr!!!
gs.info(uniqueArray[i]);
Sagar Pagar
The world works with ServiceNow
