Checkbox through macro is not visible on RITM level
Sayali_9822
Hi Team,
I have created one checkbox through macro. I'm able to check that checkbox on the portal. But when I submit the form the checkbox gets cleared on the RITM level. I don't have any clear value script for this macro variable. Even I don't select a clear value option in Ui action. and I kept this variable visible on all levels in UI policy. Please let me know a solution if you have one!
Advanced thank you!!!
0 REPLIES 0
