06-06-2014 05:56 PM
What is the difference between the Choice field type and the Reference field type? In Managed Documents, the Type (document type) field shows it is a reference field when you right click and select Show- 'type' , but it seems to be behaving like a Choice field and even provides the options Personalize Choices and Show Choice List.
06-06-2014 06:52 PM
Hi Sherry,
Here is my understanding
Type :Choice:
- if field type is choice then you see Drop-Down list of choices.(It can be reference to the table)
- The choice can be personalized
Type:Reference
- Query that displays records from another table
- Here we dont see the behavior of field as drop-down
I hope this helps
Pradeep Sharma
06-09-2014 09:32 AM
Thanks, Rajeev! I will consider your resolution as I am going back to the drawing board on how to implement this functionality.
06-09-2014 10:53 AM
basic answer a choice list is going to return a value.. this can be used as either the value or the display value..
a reference field is going to return an object... not just the display value for that object.. while it may seem a minor point it is VERY important as you work with that item to understand if it is an object, a value, or a pointer to an object as you start to use it in other places.
06-25-2014 02:09 PM
Hi Sherry,
I'm also working on Managed Docs for a customer of ours and although the type for that field is choice, it can have a reference qualifier on it via the dictionary for that field. I know it seems strange that it has two separate terms ( "Choice" in Slushbucket for personalizing layout vs. "Reference" in Dictionary) but based on how it is set up you should be able to use a reference qualifier in this case.
Just something to keep in mind.
Chris Smith
Logicalis
