client script g_form.getValue issue on referenced field hr_assignment_group
Christine A1
Mega Expert
I am using a onChange client script to clear out values or change values in other fields on the form.
I am struggling with how to get the display value of a referenced field if possible. the her_assignment_group is a reference to the Group table.
The trouble is with the hr_assignment_group. If i use the getValue, i get the sys_id. If i use the getReference, i get Undefined.  How do i get the display value? Else, what are my options to use as a condition?
alert("Hi "+g_form.getValue('hr_assignment_group'));
if (newValue == 'KM HR') {
g_form.setValue('hr_assigned_to','');
g_form.setValue('kmhr_business_service','');
g_form.setValue('hr_ticket_type','kmhr_mgmt');}
else if (newValue == 'Time') {
g_form.setValue('hr_ticket_type','time_mgmt');
dvp
You can get the name by using getReference with callBack function
Try the below script
var group = g_form.getReference('hr_assignment_group', callBack);
function callBack(group){
var name = group.name;
if (name == 'KM HR') {
else if (name == 'Time') {
11 REPLIES 11
For better performance its is always best to use call back function .
Here is an link explains more about it
https://www.servicenowguru.com/scripting/client-scripts-scripting/gform-getreference-callback/
Yes, but in your example and what they were trying to do you literally went right in to using the callback...which is literally the same thing I did and suggested.
There is literally no performance save between what you and I did.
I'm merely saying, we said the same thing, which we did.
Thanks!
I know this thread is answered but getReference() is a bit of a pet peeve for me.
it's not best practice as it returns the whole record rather than just the one value you need so it's wildly inefficient. If you just need the display value in the client you can use:
g_form.getDisplayBox('field_name').value
If you need more values you should be using GlideAjax.
Sigh...doesn't work in Client Script...
Which is why I suggested the method that I did.
Yea, ultimately, this would be better than either of the previous suggestions. So good call out.
