Client script in scoped application is not executing the script include
harika26
The requirement is to create the pop up dialog box with all the attachments that the HR case form has when ever the handover checkbox is checked.
I have written the on change client script and called the script include using glide ajax. It is showing all the alerts from client script but not giving any logs from the script include.
Any help is appreciated.
client script
    // var confirm_box = confirm("Confirm Box");
    if (newValue.toString() == 'true') {
        alert("HJ newValue---" + newValue);
        var recordSysId = g_form.getUniqueValue();
        alert("HJ recordSysId---" + recordSysId);
        var tableName = g_form.getTableName();
        alert("HJ  tableName---" + tableName);
        //Initialize and open the Dialog Window
       // var dialog = new GlideDialogWindow("confirm_dialog");
        // dialog.setTitle("Add Attachment to handover"); //Set the dialog title
       //var attach = new GlideAjax('sys_attachments');
        var attach = new GlideAjax('BICheckAttachment'); //BICheckAttachment
        alert("HJ Attach");
        attach.addParam('sysparm_name', 'getAttachmentsFromForm');
       attach.addParam('sysparm_id', recordSysId);
        attach.addParam('sysparm_table', tableName);
        attach.getXML(fill);
        function fill(response) {
          alert("HJ Response-" + response);
            dialog.setPreference("target_sys_id", answer);
            dialog.setPreference("target_table", tableName);
            dialog.setSize(500, 500);
            dialog.render(); //Open the dialog
script include - accessible from all application scopes is selected.
var BICheckAttachment = Class.create();
BICheckAttachment.prototype = Object.extendsObject(global.AbstractAjaxProcessor, {
	getAttachmentsFromForm: function()
		gs.info("HJ CHECK IN SCRIPT INCLUDE");
		var answer= [];
		var id = this.getParameter('sysparm_id');
		gs.info("HJ ID--"+id);
		var value = this.getParameter('sysparm_table');
		gs.info("HJ value--"+value);
		var grat= new GlideRecord('sys_attachment');
		grat.addQuery("table_sys_id",id);
		grat.addQuery("target_table", value);
		grat.query();
		while(grat.next())
				gs.info("HJ--grat"+grat.next());
            answer.push(grat.sys_id.toString());
		gs.info("HJ Answer"+answer);
            return 'sys_idIN' + answer.join(",");
    type: 'BICheckAttachment'
End result should be as below - I achieved it once but without changing anything it is not working again. Dont know how it worked earlier
28 REPLIES 28
your script include is in which scope?
client script is in which scope
check whether sys_attachment table can be read from another scope
Can read - true
Human Resources :core
Accessible from all applications scopes
query on sys_attachment is not working? rest all logs are coming fine?
try to create cross scope record
Ensure you are in HR Core scope
Create record like this
yes, you are right .It is not gliding to the attachments table even after creating the cross scope privilege
did you create cross scope record?
is the script include getting called?
