Client script in scoped application is not executing the script include
‎02-22-2022 11:03 AM
The requirement is to create the pop up dialog box with all the attachments that the HR case form has when ever the handover checkbox is checked.
I have written the on change client script and called the script include using glide ajax. It is showing all the alerts from client script but not giving any logs from the script include.
Any help is appreciated.
client script
// var confirm_box = confirm("Confirm Box");
if (newValue.toString() == 'true') {
alert("HJ newValue---" + newValue);
var recordSysId = g_form.getUniqueValue();
alert("HJ recordSysId---" + recordSysId);
var tableName = g_form.getTableName();
alert("HJ tableName---" + tableName);
//Initialize and open the Dialog Window
// var dialog = new GlideDialogWindow("confirm_dialog");
// dialog.setTitle("Add Attachment to handover"); //Set the dialog title
//var attach = new GlideAjax('sys_attachments');
var attach = new GlideAjax('BICheckAttachment'); //BICheckAttachment
alert("HJ Attach");
attach.addParam('sysparm_name', 'getAttachmentsFromForm');
attach.addParam('sysparm_id', recordSysId);
attach.addParam('sysparm_table', tableName);
attach.getXML(fill);
function fill(response) {
alert("HJ Response-" + response);
dialog.setPreference("target_sys_id", answer);
dialog.setPreference("target_table", tableName);
dialog.setSize(500, 500);
dialog.render(); //Open the dialog
script include - accessible from all application scopes is selected.
var BICheckAttachment = Class.create();
BICheckAttachment.prototype = Object.extendsObject(global.AbstractAjaxProcessor, {
getAttachmentsFromForm: function()
gs.info("HJ CHECK IN SCRIPT INCLUDE");
var answer= [];
var id = this.getParameter('sysparm_id');
gs.info("HJ ID--"+id);
var value = this.getParameter('sysparm_table');
gs.info("HJ value--"+value);
var grat= new GlideRecord('sys_attachment');
grat.addQuery("table_sys_id",id);
grat.addQuery("target_table", value);
grat.query();
while(grat.next())
gs.info("HJ--grat"+grat.next());
answer.push(grat.sys_id.toString());
gs.info("HJ Answer"+answer);
return 'sys_idIN' + answer.join(",");
type: 'BICheckAttachment'
End result should be as below - I achieved it once but without changing anything it is not working again. Dont know how it worked earlier
Service Catalog
‎02-22-2022 10:36 PM
you need not use GlideAjax etc to show the box when value is true
use this script and it would show the box with files present on current record when value is true
saveAttachment(g_form.getTableName(), g_form.getUniqueValue());
‎02-22-2022 10:57 PM
yes but it is removing the attachments even in the form as well, if we do it this way
In the HR Case form no modifications should be done even if in the new pop up box if we remove unneccessary attachments
‎02-22-2022 11:03 PM
why they want to view attachments on pop-up when it can be viewed on form?
‎02-22-2022 11:15 PM
when hand overing the case to incident, along with the table fields We also need to transfer the attachments
‎02-22-2022 11:22 PM
but they are just viewing the attachments and won't do any processing
then how does this help in transferring the files?
