Client script in scoped application is not executing the script include
‎02-22-2022 11:03 AM
The requirement is to create the pop up dialog box with all the attachments that the HR case form has when ever the handover checkbox is checked.
I have written the on change client script and called the script include using glide ajax. It is showing all the alerts from client script but not giving any logs from the script include.
Any help is appreciated.
client script
// var confirm_box = confirm("Confirm Box");
if (newValue.toString() == 'true') {
alert("HJ newValue---" + newValue);
var recordSysId = g_form.getUniqueValue();
alert("HJ recordSysId---" + recordSysId);
var tableName = g_form.getTableName();
alert("HJ tableName---" + tableName);
//Initialize and open the Dialog Window
// var dialog = new GlideDialogWindow("confirm_dialog");
// dialog.setTitle("Add Attachment to handover"); //Set the dialog title
//var attach = new GlideAjax('sys_attachments');
var attach = new GlideAjax('BICheckAttachment'); //BICheckAttachment
alert("HJ Attach");
attach.addParam('sysparm_name', 'getAttachmentsFromForm');
attach.addParam('sysparm_id', recordSysId);
attach.addParam('sysparm_table', tableName);
attach.getXML(fill);
function fill(response) {
alert("HJ Response-" + response);
dialog.setPreference("target_sys_id", answer);
dialog.setPreference("target_table", tableName);
dialog.setSize(500, 500);
dialog.render(); //Open the dialog
script include - accessible from all application scopes is selected.
var BICheckAttachment = Class.create();
BICheckAttachment.prototype = Object.extendsObject(global.AbstractAjaxProcessor, {
getAttachmentsFromForm: function()
gs.info("HJ CHECK IN SCRIPT INCLUDE");
var answer= [];
var id = this.getParameter('sysparm_id');
gs.info("HJ ID--"+id);
var value = this.getParameter('sysparm_table');
gs.info("HJ value--"+value);
var grat= new GlideRecord('sys_attachment');
grat.addQuery("table_sys_id",id);
grat.addQuery("target_table", value);
grat.query();
while(grat.next())
gs.info("HJ--grat"+grat.next());
answer.push(grat.sys_id.toString());
gs.info("HJ Answer"+answer);
return 'sys_idIN' + answer.join(",");
type: 'BICheckAttachment'
End result should be as below - I achieved it once but without changing anything it is not working again. Dont know how it worked earlier
Service Catalog
‎02-23-2022 06:45 AM
Is this UI page custom one or OOB?
‎02-23-2022 07:07 AM
It is a custom UI Page. Please do help me in achieving this, by tomorrow afternoon I need to close the story or else it will be an SLA
‎02-23-2022 07:42 AM
We don't have the complete understanding of the requirement.
We can just help/guide you in that.
there can be multiple ways to achieve the requirement
‎02-22-2022 10:51 PM
Hi Harika
Please try with below line
var attach = new GlideAjax('global.BICheckAttachment'); //BICheckAttachment
Lovely.
