Client script is not working for specific users
04-07-2022 01:48 PM
Hi Team,
i have created customer changes record producer for change req mgmnt
i have created a catalog client script to load put some values
i have written alert to check that script is reachable or not
i found issue with some users and a pattern
if i create a user in sys_user table and assign company and " itil "and "snc internal role" --client script is working fine
when i'm creating user from core_copmany giving same roles was not able to access client script
note: Both users are having same roles same company
it simple client script nothing complex
consider only one line of code alert("reacgeble load script");
can anyone help me overcome the issue
Change Management
04-07-2022 11:28 PM
both are having access to form only issue is client script is not reachble
04-07-2022 11:50 PM
Is the client script not working for that user in native + portal?
can you share that client script configuration screenshot
04-07-2022 08:06 PM
Unfortunately you haven't shared script or screenshots
